I've been researching upgrading the crossovers in my Polk Monitor 10s for awhile. I've upgraded the tweeters to RD0-198s but have decided swapping the capacitors would also be a fun project and from what I've read will improve the sound even more.
So far I haven't been able to find a schematic that's specific to my speakers. The closest I've found is in a thread over in the Polk forum on a set from 1990: https://forum.polkaudio.com/discussion/190873/monitor-10-series-2-crossover-upgrade
As you can see from the attached photos, mine are a little different. The 27 uF and 12 uF caps are straight forward. What I'm unsure of is the yellow cap with the blue 12 uF cap on top. The yellow looks to have 14J 100V on the side but I can only see half of the numbers.
What should I be replacing the yellow cap with blue 12uF cap on top with? Other forums suggest 16uF there, and that's what the 1990 schematic suggests, I'm just not sure if my 1992 pair should take a 16uF there as well.
Also curious what the best way is to cut through the existing hot glue once I get to that step. I'm extremely new to this so please bear with me. Thanks!
