Hello and maybe someone will have a suggestion to help me wrap-up a project.
It's a 2215B that I found last year, cheap, "for parts" with a channel out. $60 and it's in nice shape! I've done a lot of work on P700, P400, PE01 and P800. It's the first Marantz I've attempted to fix/restore.
First I found that output transistor H712 tested bad and so did R736 and R738 - replaced those and that actually fixed it. I've been listening to it with headphones for months now as I worked on boards here and there as I could find time. The adjustments worked fine - no issues. I followed the patfont procedure.
It sounds GREAT with headphones and speakers off. Fantastic! I could hear the effect of the new caps; pretty cool. It's also very quiet with no hiss. Nice solid bass and clean, clear highs.
However . . . with speakers, it only sounds great up to about 10:00. Past that point, which is pretty loud but not not beyond reason, there is some distortion, mainly in one channel but I think I hear it in both at times. Once the distortion starts if I switch to headphones I can hear it there too so I know it's not the speakers themselves. It's kind of a "fuzz" or buzzing sound that follows lower frequencies and even remains at say 9:00 volumes with headphones once it starts. High frequencies still sound crystal clear and awesome.
So it's a problem that shows up at relatively high volume but not with headphones alone. When I start to push the amp.
I replaced everything on the power supply board except ceramic caps, the two big resistors and H801 which is a 2SC1407 - just left that alone. Tonight I pulled and tested R801 (330 ohms 3W) and R802 (220 ohms 2W) and they tested fine, but I'm planning to order replacements.
I could put them back in and do some more testing. I wonder how you guys would track this problem down. I'd really appreciate any suggestions. Thanks!
Attaching a few pictures:
These tested fine but maybe they should be replaced; I'll have to order:
Just about perfect shape!
PS board with those two resistors pulled at the moment:
Here's my P700. I went cheap and used Amazon metal film resistors for the .47 ohm ones (4). Maybe I should get some better wire wounds for those spots. I also replaced the carbon composites with metal films but left the others.
