2275 Re-cap journey...DONE!!!
Howdy AK, just thought I'd show you the progress of the re-cap I'm doing with a trashpicked 2275. Fires up, but there's a 60Hz hum in the output as well as poor FM reception quality.
Started with the power supply board. All caps removed here, some were definitely burst. What is this stuff on the PCB? Some sort of epoxy?:
Old caps out:
A close up of the bigger ones with the gunk on the PCB. I cleaned that gunk off before I proceeded:
All done! Silmic II's were the replacement of choice for this one. Phono board needs some help and the P700 power amps are all original, will go after those ones later.
Question: for the 35V adjustment, should I be doing this in-circuit with the output stages connected? I currently have the L&R power amps disconnected as I'm evaluating a re-cap procedure on those. Thanks!
Old caps out:
