I know there are a bunch of threads on this, but...I figured if I gave my equipment, answers might be more specific to me:
Sony STR DH90 (90w/ch) receiver, specs say 6-8 ohm. Using a Dayton Audio 1200 sub, connected from B speaker outputs to high level input. It's powered, of course, so I'm not even sure if that has an effect, with using the B speaker line.
I was looking at a pretty good deal on Sonus Faber Lumina II, but they're rated at 4 ohm.
I typically have relatively short listening sessions (about an hour), at about 70-75db in a 16x22' room.
I've seen many say that I should be fine as long as I don't play too loud, too long, and stop if I hear clipping. And that the receiver would likely be the fail point, with most have built in protection.
So, thoughts? If the receiver fails, that'd be the preference. It's obviously not as expensive as the speakers. But of course, I'd rather not replace it, and definitely wouldn't want to pay for the speakers and damage them. And also, I have a Yamaha RX-V481 (110w/ch) I could use if better suited with more wpc, but it's also 6-8 ohm. So how "safe" would it be using the Lumina, and which receiver would be better to use?
