40uF 350V Capacitor
archie2
Addicted Member
Doesn't anybody manufacture a 40uF/350V electrolytic capacitor anymore? I know of one place but I'm not going to wait 10 days to have it shipped air mail from Canada.
I mistakenly ordered a 20uF instead of a 40uF and cannot find a 40uF/350V or higher anywhere. I can find a 47uF and a 33uF, which is closest and how much difference will it make in an integrated amp?
Considering that vintage capacitors were rated -20 to +80% tolerance, a modern 47uF capacitor will be very close to the original. I wouldn't worry at all with that small upsize!
Good info. In that case I'll order the mini 47uF/450V one from PE. The small size is to my advantage because I'm mounting these under the chassis where room is a bit tight.
How about...
..this one?
$1.45 a throw. I've used these on multiple amp rebuilds, and had no problem whatsoever....
Good point. I read somewhere that you can increase capacitance by 10% with no problems as long as the voltage rating stays the same or is increased.
jon_s, how do you like the multi section JJ caps shown in your avatar?
As the others said, the extra 7uf won't hurt anything. tubesandmore. com (A.E.S) has Sprague 40uf caps if you want the exact value.
a higher V rating is good as it allows a higher working V less chance of breakdown/shorting. And 20-100% over cap value doesnt hurt either. just gives more energy storage and less pwr suply sag at low freqs.
22, 33, 47, 68 are the standard values these days. Since the tolerances are so wide, the 40s may be other value caps re-labeled as 40...
