So, with this board that you are currently working on (assuming the left channel board), what is your +voltage rail coming into the board at J722? It should be around 48VDC.
Also, just to verify, ensure that your output leads are going to the correct pin locations on the board. Here is a good reference:
Try removing the base at H001 and see if your bulb goes dim. If not, then try H003. You need to find where this excess current is coming from. If the DBT goes dim, then you've eliminated the output stage as the issue. Work your way back from that output to the C726 as that is the output path. With my experience on these P700 boards, the usual culprets are either the outputs, emitter resistors, or the driver transistors. I would check all of those out of circuit.
Also, the way this boards looks, you may have a solder bridge, a marginal cap, or a stressed component.
If the other board does not have significant solder and burn issues, then you may want to start with that one and get it up and running first, then work on the one in worse condition. If you have one working board, it's useful to help with fixing the other.
