Use the 4 or 8 ohm taps. Either is safe and you can use the one that sounds best to you.
Thanks,
Ron-C
How does McIntosh autoformers perform with 6Ohm speakers? I mean, they are usualy 2,4 and 8 Ohms, right? If I buy, say, 6900 and pair it with 6 Ohm speakers lik Sonus Faber Concertos will I loose something in power and sound quality?
I know I can, but will it sound best? And how much power will I loose?:headscrat
If they only made speakers that would have a straight line impedance curves. They are usually all over the place from as low as 2 ohms all the way up past 25 ohms even though the nominal impedance may say 4,6 or 8 ohms. Play around with the taps and go with what sounds best to you, you are not going to hurt anything.How does McIntosh autoformers perform with 6Ohm speakers? I mean, they are usualy 2,4 and 8 Ohms, right?
Couldn't you connect a speaker to the 2-Ohm and 8-Ohm taps of the autotransformer to match a 6-Ohm load? Assuming, of course, that you have a 2-Ohm tap.
I don't think that would be wise.
My speakers are 4 ohm and I think the 8 ohm tap sounds the best, so that is what I use. Victor
Victor, what exactly do you notice that sounds best using the 8 ohm tap? Why wouldn't the 4 ohm tap technically sound better since this is how McIntosh optimized the design of the speaker and amp?
