markmcmuz
Well-Known Member
I had solved some issues with this project thanks to folks advice here. I now have correct b+ voltages at all tubes, heater is 6.1 volts ac, I'm able to bias the power tubes to 20 mv (one tube is a little higher- 7 mv). Now I have a loud and I do mean loud hum when I connected speakers. I connected my oscilloscope and was able to identify a 60 hz signal that is amplified to over 5-6 volts with no input connected. Some of the things I have done in this build is connect the PT center tap ground to the can cap ground, use shielded cable for the inputs connecting the ground wires together at the RCA end (but not grounding there) and grounding the other end near the AF cathode cap grounds. Not sure where to go from here as I've scrutinized the build and can't find any glaring problems. However I am a greenhorn. Any help would be appreciated.
