Carbsandcaps
I ordered 3 sets of 6p14p-k (K is the inportant part here) tubes and have had nothing but problems with each set. In a fixed bias amp the were pulsing blue inside the tube (not arching just pulsing) and the bias was jumping all over the place this would happen when there was no audio signal only. In a cathode bias magnavox build, bias would hold for about a minute then slowly start to rise from 6.4v up to 12v on the cathode resistor and not stop until I turned the amp off. Even with the coupling cap disconnected I had 10v on the grid. I finally found 2 tubes of the set that would hold bias. It seems like anything that disturbs them like unplugging the rca inputs or even just moving the tubes drives them crazy.
I’m not sure exactly what’s causing it but I’ve read that the K version are not good audio tubes but they are for pulse applications. I’m starting to believe it. Anyone have any experiences like this with the K version?
