Check all fuses and make sure they are ok. The 9090 also has fuses on the driver board as well as on the power supply board.
Check the relay connections and make sure the foil didn't break anywhere while you were removing or reinstalling the relay.
Exercise the tape monitor switches, mono/stereo, and speaker switches to make sure one is not spotty.
Check different functions such as AM, and FM and aux or phono input.
If you still can't get sound on the left, remove the 2 "U" shaped jumpers in the back. (Pre Out, Main In). Use a set of audio cables with RCA plugs at both ends similar to the ones you would use for connecting up a tape deck. They are color coded so you will know matches on both ends. Cross the cables so that the Left pre out goes to the Right Main in, and the Right pre out goes to the left main in. Turn on the unit. If the left is still out, you probably have a driver board or output transistor problem (expected due to the welded relay contacts). If the right channel is now inop, suspect a really dirty switch, or a tone amp/preamp problem like an open capacitor or bad transistor or BA312 IC.
