bbqjoe
Void where prohibited
I have a sinking brake pedal.
I have also never had a Ford truck with outstanding brakes, but I believe these could be better.
I just replaced the brakes on the rear, including wheel cylinders.
Brakes bled, and adjusted, but still have a pedal that sinks, although the brakes are better than they were.
I did some research, and a bit of yootoobing, and it looks like the next things to troubleshoot are the ABS hydraulic unit, and the master cylinder.
Possibly the booster, but I'm tempted to believe it's working.
I've never dealt with a clear plastic master cylinder reservoir before.
Something I did notice when bleeding the brakes was that I could see fluid flowing upward in the reservoir at the rear of it when the pedal was pressed down and bleeders were closed. Not a geyser per se but definitely a good upward surge.
Is this normal behavior for a MC, or is it an indication of a bad MC?
If that's normal, I may have a look at the ABS unit, but for the price of a reman, I might just bypass that piece of junk.
