Resurrecting an old thread and EQ.
I also have a ADC SS3 I purchased new back in 198? After starting the old system up again this week my SS3 also has the tapping sound coming from the right channel. Sometimes it takes a while to start. It almost sounds like a spark jump or a static spark. It stops when the Bypass switch is engaged. Anybody have any idea what to look at or replace before I have to send her to the hay loft in the barn ?
:tears:
Got the same problem on mine after 10 years in the dust. I arrived here tonight to find a solution, and I don't, but I find myself...
So, you need:
- 150 bucks
- A car
- 3 months
- A good repairman
or:
- A contact bomb (or anti scratch: near the same product, but better)
- 30 minutes of your time.
The problem come from the low switches line (3 positions switches under the faders). There is oxydation, and I suppose there is somewhere a condensator that can't work properly with this bad contacts. So put anti scratch anywhere on this line (with a little tube to pass the holes in the front side) and move the three position switches up and down (24: I know it's long). Let it dry. You can do the same with the other switches, it can't be bad.
Put the EQ on the amp line, with a low volume. Move the first switch of the low line up and down, and continue to do it till the sound doesn't scratch. Do the same for The 23 next.
When it's done, put the volume up: normally no tapping, no blow: just a nice withe sound. If not, goto line 1.
I think it could help. (for the english quality, don't be cruel: I'm french...)
Any help on SM would be great, thanks all
