I bought a NHT sub from Crusty, I mean Grumpy and should hit the shop by Friday. But unsure on how to hook it up.
My Adcom GFP-555 has two main out put's listed as follows.
Main Outputs LAB or Normal outputs.
Lab is for ADCOM. The GFP-555 was designed with an output idealy matched for opretion with the ADCOM GFA-555, GFA-545, and GFA-535 Power Amps.
Normal is Capacitances coupled for lesser amps.
That is the short verson, real short I might miss spell.
Here is the question I use that LAB outputs for my ADCOM GFA-555's power amps, can I use the Normal Output for the NHT Sub Power amp at the same time I use the LAB output?
Have not been too DR HI FI for a while and like to keep it that way.
Cuda Ken, going to have a lot of Shakeing going on
