Nice forum! It's been interesting browsing here and learning. My apologies if this has been covered before, but I didn't find anything doing a search.
I picked up a Realistic STA-21 recently, probably payed a bit more than I should have, but it just paired too nicely with some Realistic speakers I had been using to pass it up. Two of the three display lamps were done, but after replacing them with some LED lamps, it's in fine shape.
I've been running a Bluetooth receiver into the Aux input, and I'd like to move it inside the case. I've been using the little Drok boards for small projects, and their latest Bluetooth receiver will do the job nicely. It has an antenna jack so that I can get the signal inside the case, and needs DC 5-12V supply. Before I open it up and start poking around, I'd like to know if there are some obvious places to tap into DC voltage. I'm not totally unfamiliar with electronics, but I have little experience with receivers. I see in the manual there is one (!) IC, an LA-3350. Normally I'd look at the chip's Vcc, but I can't seem to find a pinout for it.
Does anyone have an idea where I might tap into some DC 5-12V?
