Have you replaced the mounting gasket material each time you removed & replaced your woofers on the speakers with the lower bass output? Any air leaks will reduce their output. Acoustic suspension needs to be airtight to be effective. Same to be said with the tweeter & midrange gaskets as they share the same air chamber with the upper woofer if memory serves me correctly. Been awhile since i opened my 810s.
