Advice Request
coleyzzz
Hello, I am looking for some advice on purchasing a new AV Receiver. I am more concerned with music than anything but I will be using the AVR for home theatre as well. As of right now, I have a Yamaha TSR-5790 that is hooked up to a VIZIO E-Series 55” Class Full-Array LED Smart TV | E55-C1 that I one day will upgrade. Other than that it's hooked up to an Xbox One as I am an avid gamer. I do plan on one day acquiring a pair of Cerwin XLS-12, but not sure when. I have about $750-$800 to spend. Here is a list of me speakers that I have purchased within the past 2 and half years so I am still breaking them in. I like to mix and match my CV's. Thanks in advance for your help.
Pair of CERWIN-VEGA SL-28 DUAL 8 INCH 2-WAY FLOOR TOWER SPEAKER
Speaker Type 2-way floor standing tower
Drivers 2 x 8.0" (20.3 cm) woofers
1 x 1.0" (2.5 cm) soft-dome tweeter
Frequency Response 32 Hz to 26 kHz
Maximum Power Handling 300 W
Sensitivity Peak: 89 dB
Nominal Impedance 8 Ohms
Protection Features Fuse
Pair of Cerwin-Vega XLS-28 Dual 8" 3-Way Home Audio Floor Tower Speaker
Speaker Type: 3-way floorstanding tower
Speaker Compliment: Dual 8" (203 mm) cast frame high excursion woofers
6.5" (165 mm) woofer with fiber impregnated cone
1" (25 mm) soft dome tweeter with ferro fluid
Frequency Response 45 Hz to 20 kHz (-3 dB)
38 Hz to 20 kHz (-10 dB)
Maximum Power Handling 200 W
Sensitivity 89.8 dB (@ 8 ohms @ 3.3' / 1 meter full)
Impedance 6 ohms (8 ohm compatible)
Crossover Frequencies 380 Hz / 2.4 kHz
Protection Features Fuse (3 A 250 V Slow Blow, 6.3 x 32 mm)
Pair of Cerwin-Vega XLS-6 6 1/2" 2-Way Home Audio Bookshelf Speaker
Power Capacity: 125 watts (Peak)
6.5" Woofer with Fiber Impregnated Cone
1" Soft Dome Tweeter with Ferro Fluid
Frequency Response: 50 Hz - 20 kHz (-3 dB), 39 Hz - 20 kHz (-10 dB)
CERWIN-VEGA SL-45C QUAD 5 1/4 INCH CENTER CHANNEL SPEAKER
Speaker Quad 5.25" (133.3 mm) drivers
1" (25.4 mm) soft dome tweeter
Frequency Response 55 Hz to 26 kHz
Power Handling 300 W peak
Sensitivity 89 dB peak
Nominal Impedance 8 ohms
I have 2 Subwoofers-
Infinity Primus PS312 12-Inch 400-Watt Powered Subwoofer (Black)
Single 12" (300mm) MMD driver.
25Hz - 150Hz frequency range.
400 watts RMS.
700 watts peak.
50Hz - 150Hz 24dB/octave continuously variable.
Five-way binding posts.
Yamaha YST-SW012 8-Inch Front-Firing Active Subwoofer
8-inch multi-range driver with magnetic shielding
High 100 W dynamic power
Low (28-200Hz) frequency response
Linear Port for minimizing extraneous noise
Front-firing active subwoofer
You must like bass :). You might want to try the home theater section for advice on avrs as most of us two channel folks don’t use them. I can say I liked denon when I had one.
Cerwins are not the most refined sounding but I like their big size and for Rock, they are fun speakers.
You might want to hear other speakers at your local hifi shops in the future for other genre music though since you already have many Cerwins.
For receiver, I would consider this for $500 new:
Cambridge Audio AXR100
It has torroidal transformer for upscale warm sound.
