inkman69
I took my SX-1250 to a local repair shop. The unit was shutting down at a little over 1/4 volume and was needing a good cleaning inside. (I bought this unit from a co-worker who had it stored in basement for several years)
I got the call yesterday telling me that all 4 large capasitors (around the transformer) are bad. 2 are not very low valued and one is cracked and one is cracked and leaking all over board. He says this is whats causeing my voloume problem and that It will gradually get even worse. Said this is caused from the unit sitting for a long time and then powering up again. That these were made to be played reguarly.
He says its fixable....He says he can get Pioneer origanal capasitors at 90.00 each (he says they are hooked up and mounted with screws an easy fix for him. The other way would be to use aftermarket compasitors at 20.00 each,but he would have to rig these up but can make them work. But the values are diffrent , i dont remimber the values what he was saying and im not a repair man.
I was surprised that he says he can get origanal pioneer parts.
was woundering if anyone in here has any experianse in this type of repair?
my other choice is ....I have another SX-1250 in much nicer condition...very clean. It has a problem with the ballance controle...it quits on the right side....i sprayed it before with radio shack spray when i had the faceplate off and it worked fine for a couple of months. But is in need of a spray again. And the Loudness switch cuts off also.
So I have two units with issues and thought about taking parts from one to make a good one. and keep the parted onr incase of another break down.
what would you all do?
Thanks Inkman69 :scratch2:
