Akai AS-1080 Receiver - Lamp Size?
Haileyburian
AK Subscriber
Can anyone tell me what the lamp size is for this unit?
The Akai AS-1080 is a 4-Channel Receiver, with circuitry for CD-4 and SQ. Tuner dial has 4 lamps along a 'light bar' that seems to do double-duty as meter illumination...
I assume that you mean the size as far as what voltage the lamps need to be. I've just always placed a voltmeter across the leads on the unit. Get as close to the correct voltage as you can find and should be good. A slight variance shouldn't matter. This works even if the bulb is burnt out.
Would like to know voltage/amperage and 'physical' size, ideally from someone who can confirm from Service Manual or other source...
