I have the service manual but I dont have an O-scope, or the meters needed to calibrate..or the know how. My rig is record challenged big time. 3 head unit has a head skew issue. I can get pretty good playback but the record is terrible. It wanders in and out in sound and on the VU meter, and when I play side B I can hear side A backwards ! The head block has 3 adjustment screws: 2 allen screws top and bottom to adjust the head tilt and tape path "depth" by turning them both at the same time. The azimuth screw on the left side just rocks the head on the 2 allen screws against a spring on the right side. So PB/R azimuth is a ballet of azimuth adjustment as well as tape path depth adjustment to get the record head back on track once you tweak the PB head as they rock in different directions. I guess the price we pay for a 3 head deck. Add to that is the fact that this deck needs to have the front face removed to access the lower allen screw (?) and that takes the cassette door out of the adjustment. Does the tape door pin the cassette back against the "wall" on the drive heads, or does it float in the door mechanism because you need to play a tape in order to adjust the azimuth Whats the going price to get a deck back to par? Im in So. Cal.
