Does the driver disassemble at all? I'd be tempted to separate the basket from the magnet and try to move the coil inside the gap to achieve smooth movement. Not sure if you would be up to that.
Wait, I get it.
I'll try it now.
EDIT: Holy moly! It worked!
Just loosened the 3 screws, tapped it with a small hammer, problem solved.
Brilliant!
Funky looking speakers.
Yes, don't be afraid to give them some juice, they sound good with some watts put to 'em. As Biggs said, those are definitely not early tweets. They are the b200y aluminum tweeters and have better highs than the earlier paper cones with aluminum (shiny) dust cap. The rest looks pretty standard early generation stuff although it's unusual that the woofers don't seem to have the label on them (would expect they would have the blue and gold decal colored like the crossover one on the magnet cover). Appear to be first generation Paper Mids and Woofers. Can you make out date codes on them? They are easy to decipher. The first two digits are the year of manufacture. The mid looks like it may start with '60' the trailing numbers indicate the month. I very much doubt these are prototypes but look like factory 302as to me. They either had legs or risers attached to the bottom. I have not seen risers that have a tilt but that would actually be a great idea. Maybe the PO modified these to their tastes?I'll keep writing notes on this thread for future reference.
These things like power.
I was thinking originally it might have been a mono system (1960) and the second was added later to make stereo. That could explain the different finishes. Just a thought.
