For most SS amps thats of no consequence. For tube amps and Mac amps with Autoformers preceding the 7000 class amps you may find a difference. 16 ohms gives you more voltage to the speaker but less current and if the impedances get below 12 ohms that maybe an issue for a particular amp. I would start with the 8 ohm tap. Listen for a day or so to get accustomed to the sound and then switch to 16, you'll either be surprised and really like the change or there will be very little difference in which case you stay with 8 ohms. Each amp will react in a different way. Now if you said a MC275 I would say 8 ohms, A 2105/2100, 8 ohms, and Marantz model 9 16 ohms. Ive been there and done it at the Hi FI shop and at the Radio Station. Dyna kit Model III 16 ohms. My MC 60's I liked 16 ohms, but a 275 at 8 ohms was truer to the original performance. But the best sound comes from SS amps Like DC 300'a, Mcintosh 7100 and 7200, and MC 502, that are direct coupled. Be careful I would imagine the crossover caps are compromised due to age, and should be replaced before applying much more than 2 watts of music to the speakers.
