Altec Lansing ALS 85’s
Markmayne
Member
I need help with some bookshelf speakers they’re Altec Lansing ALS 85 need to find a piece for the crossover. If anybody has any spec sheets or schematics for the speaker that would be helpful. Or if anybody knows the name of the missing part and where I could order it..
Iron core
Air core
For the price I would get the air core. And replace the coil in both speakers so they match. It will hang off the board a little bit but that doesn’t matter. Glue that sucker on with hot glue.
How did you end up with a missing inductor?
Iron core
Air core
My father in law dropped the speaker down the stairs. When he connected the speaker the woofer wasn't working so he dug in to fix the problem. A day later I got a picture from my mother in law of him surrounded by a mass of unspun wire......pretty funny. So that is situation. Thank you for the advice and I will grab 2 of the Air-Core's.
I will send a pic when I finish:)
Looks like it’s missing a 1.5mh inductor…
Should look like this.
I know this is an older post, but was wondering if you had upgraded the caps on this? The ones on mine are 8.2uf electrolytic caps, same value on both and measure at 19.xxuf. I was looking to maybe upgrade the crossover with a couple poly or film caps, an air core inductor, maybe different resistors. Would you have any recommendations on what one could change the values of or anything that would potentially improve the stock design?
Thanks
