ericross3
Member
I've been wanting to do an "traditional" Econowave build for the longest time. I've been targeting Altec model 9s. I've always thought these would be ideal candidates. A horned two-way version of the 9s should get me closer to a model 15 (they share the same woofer). Scored a clean set cheap. So, here I go.
I plan on using the original configuration as much as possible, even the port. Woofer: this is the version one model 9 with the (less desirable) CTS woofer, but that's fine. Tweeter: I planned on just buying some d220ti's and using the, now standardish, Dayton waveguides. That is, unless someone else has a better (closer to a model 15 sound), but no more expensive idea.
That brings me to my questions. I'm not very experienced figuring out crossovers, but can solder and fabricate very well, so...1) What type of crossover should I build for the Selenium/Dayton combo? 2) If I should use something different, what should that be crossed over with?
Thanks in advance for any help. I'm going to attach pics I have, and will post more as I put these together.
