Hey folks, POlease help. I have rebuilt an amp I got off the auction site. This was a national or a merril - not sure. It uses four 6v6, two 6211, and a 5r4 rectifier.
I have replaced all of the coupling caps, the multisection cap and almost all of the resistors. I have added a fuse and a three prong ground cord. When I rebuilt the unit I made multiple ground loops - everything is point to poi9nt wire grounded now - not just chasis ground.
When I started the project the hum was there. It is still there. It is barely audible. two things affect the hum, first being powered on or off. When powered on, it takes a few seconds until the tubes warm up and then the hum appears. When shut of the hum stops instantly. Second, the 6211's seem to vary the degree of the hum. Different tubes change the output levle of the hum(louder softer). Not significantly but some.
I have swapped tubes around and right and left inputs. I have also tried several different 6v6 tubes.
So any ideas? It seems to me to be either a power supply hum, or the 6211 tubes are a very noisy tube. Anyone know about the 6211?
Mark
Mark
