Dear All,
I have a strange problem with my audio equipment.
I bought an amplifier (from 80's, old Denon PMA-860) for which the source (via AUX input) was DAC Dragonfly Black v.1.5 (connected by minijack-RCA cable). After several hours of playing occurred problems with the left channel - began to play more quietly. Switching the amplifier off, turning the power plug by 180 degrees and on again was solving the issue for a while. After few days the left channel began to hiss (even at the minimum volume) until it finally got stuck.
The amplifier has been repaired - power terminals were damaged.
I've connected repaired amplifier with DAC - after a few dozen same problems occurred. I've changed speakers for another pair - problem still persists. I changed the amplifier to another from the 80s. After several days left channel began to "click", hiss, etc.
Throughout the whole time, the DAC plays without a problem (headphones plugged in - everything is perfect).
What is causing the problems described above? What should I redesign in connections/devices to solve the described problem? I came across the opinion that old audio equipment is not adapted to the signal (high frequency or something like that?) broadcasted by the modern equipment. Is it true? Does change to another DAC (with dedicated RCA outputs) may solve the problem?
