gp1680
Hey all! I need some help. I recently acquired a pair of AR-2ax's for $30 off CL. I brought them home and fired them up. Of course, the tweeter/midrange on both were not firing. One of the woofers was shot and the other coughed meekishly. I opened up the babies and found everything was original, including the batting. I pulled everything out. Replaced the caps in both. Replaced all four pots with new ones. Found a single woofer on fleecemebay that was an original six-screw and threw that in. I then replaced the batting with brand spanking new r-30 certainteed insulation. Sealed the woofers back up with sta put. I then uncovered my 8080db and brought it out to fire up the puppies. I put in some Coltrain, then Santana, then some Fogerty. After tweaking the mid-range and high controls, GREAT GOD OF AUDIO! I really like them. They don't have the bass response that my Pioneer CS-A700's have, but they have a very smooth sound to them.
Now here's where I need some help. The cabinets are in need of sanding and refinishing. I have two stains that I use pretty regular - Watco med walnut and dark walnut. The danish oil is great stuff. Easy to apply. However, I'm not sure if I want to give it a walnut stain or a red mahogany. Has anyone refinished these cabs before and what did you use?
