Eminence1963
One of my tubes red plated this morning had a buzz in the right speaker. I'm new at troubleshooting so my question would be swap the tube out and turn this amp back on and cross my fingers that it was just a tube or before I turn it back on and replace that tube check something further in the amp that might cause that particular tube to Red plate? The amp in question is a 25 watt per Channel push pull fixed bias amp. I did pull the bottom cover off the amp and did not see any of the capacitors leaking nor did I notice any of the resistors burnt. This is all done by visual inspection nothing on the circuit boards looked out of place. All the wiring looks intact. I am not sure how long the tubes have been in this amp as I have owned this amp for the past 3 years, bought it used run it every day for at least 8 to 10 hours. Never run the amp hard just a normal volume level background listening music mainly. There are no fuses inside this amp the only fuse that is on this amp is the main fuse to the power cord. Fuse never blew.,
The amp in question is a Shuguang I25.
