basil13
I have an amp that has me scratching my head and could use some more eyes or thoughts. I will spare the long story for now. As it sits the amp won't come out of protection, there is very little dc offset (15mV) and I have checked all voltages on the power amp board and nothing stands out. I have replaced the 726 transistors.
I see that Q5 on the protection board is on (0.6V between the base and emitter). Looking at the schematic, it appears it should normally be off (20.4V on the base, 17.9V on the emitter). The thing is I have the amp apart and the outputs are removed so it can't be in overcurrent???. I have disconnected outputs in other amps in the past and never had it cause relay issues.
Does the 9500 need the outputs installed for the protection circuit to work properly or do I have something else going on?
Thanks
Thanks
