Another "what to buy" thread: ~$1000 budget after speakers and turntable
FrayedWire
I think I'm living in a bit of a gap in the market budget-wise, but I wanted to double check before deciding on what to do by myself. I've recently moved across the country and am starting over on audio equipment, and I'm trying to decide what will be the power source and brains for my new setup. I am pretty set on a Rega Planar 1 for the turntable based on the TTs I've been able to hear in person in my budget, and I am also pretty sure I'll be getting some Toby speakers from my hometown of Fort Worth, TX, for both price-performance ratio and sentimental reasons. I'm going with a pair of relatively small profile floor speakers, which will be more than adequate in my walk-up apartment in Manhattan. I don't expect to be living in the same place in five years, so that's also a factor. I don't care about movies or anything but music.
The hard part for me is the receiver/amps part of the system. I mostly listen to digital music, but I also have a fair bit of vinyl (and I'd like to use it more), so I would like a relatively painless way to switch between the two, and a pre-amp for the turntable. I previously handled this with a vintage receiver and an iPad.
I don't really want to spend much more than about $1000, but it seems like while I can come up with a good set of amps for the purpose for, say, $2500+ total, or a decent set of choices of AV receivers for $300-400 (plus a preamp), there is not a lot in between that upgrades the audio rather than the video and bells and whistles parts of the equation. Is that a fair assessment, or am I missing something? Should I just buy a $300 Pioneer or Denon receiver and think about a more serious upgrade down the line, when I'm in a more permanent home and willing to spend more money? Should I buy the same and pair with a low-end two channel power amplifier, maybe something from NAD, even though it seems questionable how much extra quality I'd get out of something that costs $300 (or is that unfair? I don't know anyone with such a setup and so I'm not sure how to do a proper test)? Stretch my budget a bit and get something like a Marantz MM7025? Go back to vintage? I like vintage in principle but not sure I have the time or appetite to go that route properly at this point in my life.
I appreciate your thoughts.
Look into Emotiva gear. Great products and great service at very reasonable prices. I own many of their units and I'm very happy...cheers DG
Thanks, Emotiva has not been on my radar. Are you thinking something like an SP-1 paired with an A-150 or an XPA-2 if I decide to blow my budget? Any experience with the A- line versus the XPA line? It's kind of a bummer that I can't listen anywhere before buying, although it's nice that they at least allow a thirty-day trial.
Kind of considering pairing a Musical Fidelity M2si with either an LX2-LPS or a preamp from another manufacturer now, although again I wish I could listen to the setup without committing to it.
I am looking ahead to less and less ability to lift stereo gear, so I am looking at the EMOTIVA integrated amp/tuner as a possible replacement in the future.
I would think there are oodles of stereo integrated amps with phono stages right around $1000. The M2si looks plausible, esp. if you get it for $599 at Upscale Audio and have the rest left for a phono stage. Judging from my friend's SR7008, Marantz is making very good sounding units these days, including the phono stage. A lot of folks here like Yamaha, too. If you go with separates, you'll probably need to mix and match, including some used pieces. IMO, used doesn't represent the value it did a few years ago, on average, but there are always exceptions.
A Yamaha A-S501 isn't the sexiest choice, but would likely do very well for you until the next move, or next upgrade, at a nice price. Later you may find it useful for a bedroom secondary system.
You mentioned receiver and vintage. So, it's hard to beat a $175 and under to the door vintage receiver for what you want to do. Tried and proven all in one method since new from back in the day.
These are the common deals that perform to the point of diminishing return. All true 40 plus RMS x 2 watts with good phono sections..
JVC vr-5551, Is the first choice, then these.in no order.
Rotel RX-800
Lafayette LR-3500 (Planet Research)
Kenwood TK-140x
Yamaha CR-600
Realistic 120B (Hitachi)
Sony SR-6065
And some very good newer receivers from the 80's.
Do not get the Lafayette LR-1500ta, no speaker protection at all, none!
From there the price for the "little darlings" zooms right on up, you mentioned maybe short term and price. These will get the job done nicely, so. And your good enough Pioneer SX-780 that's not as good? Will start at $250 plus the ride.
Good luck.
Another vote for the Yammie A-Sx01 series. The 501 is the best deal, since the price for its bigger brothers jumps dramatically, and it is not likely that in a Manhattan apt., that you are going to be really cranking. Cambridge Audio is another option to consider, although most of their stuff will require an external phono preamp.
That's true, the more I look the more I find more options than I saw right away. I had been thinking that most of the ~$1000 amp options would demand at least a separate preamp and maybe a separate selector of some kind, but it seems like that's not universally true. The M2si is really intriguing, as is the Yamaha 501 that others are suggesting and then having several nice dinners left over . . . I'm tempted to go Yamaha because of the wealth of enthusiastic recommendations I find on here as well as the eye-catching price. And as savatage points out, I'd have to factor in the cost of an eviction if I really took advantage of any of this hardware in my current living space.
It's really hard for me to turn my back on the vintage approach, but I seem to quickly accumulate half-working components and digikey bags a lot more quickly than working systems so I think I'm going to go new this time. I put the boards together for a couple of Amp Camp amps from DIY Audio for my office about two years ago and have yet to get around to putting them in a case, so I'm trying to be honest with myself. If I knew of a reputable and affordable shop that worked on vintage stuff near me that would be a different story, but everything around here seems to be aimed at the ultra high end.
I discovered that the A-S501 is on sale for $440 on Amazon right now, so I couldn't resist pulling the trigger on one this morning. Hopefully not passing up too much of a good deal on the Musical Fidelity hardware, but I figure I'll be happy with the Yamaha for a while and another good deal will pop up down the line. Now to put some time into getting my Amp Camp boards into service now that I've outed myself online.
Congrats, and I don't think you will be disappointed. I almost bought one myself for a spare bedroom system (when they were still $500-550), but I got a "steal of a deal" on some gently used Cambridge Audio stuff in the the same "class".
Best of luck to you!!!
Cool, and less than 24 hours.
