As my next silicone motor mount project, I've been asked for making the ones for sixties and early seventies JVC et al turntables; basically the generation preceding the JL-xxxx generations. I would speculate this may have been the last generation of mechanical JVC tt:s built in-house; mostly based on what I've seen of the motor mounts and other details in the later models.
I've previously come across pictures of these parts, and noticed them as possible parts to add to my stock, but since they all are very rare where I live, I doubt I'll ever come across any live ones. Now that I've got the measurements for the parts and a willing test pilot, I'm about to start working on the first version.
The parts were used in several idler models, including srp-471, src-700, src-900, arc-15, and arc-15. My problem is the scarcity of techical info on this generation of machines. The ones I've listed are what I could find at VE. I know of the existence of some additional JVC/Victor iders, such as 5250, 5250, srp-467, SRP-47, and SRP-B20, but I have no idea of what kind of motor mounts was used in those. I have a hunch the same parts may also have been used in belt drives from the same era, but I haven't found any info on those. (Partly due to the download restrictions at VE; it will take some time to skim through them all).
The parts I'm after are these:
This is a shamelessly stolen photo from this VE thread about restoration of a SRP 471E-5 here: https://www.vinylengine.com/turntable_forum/viewtopic.php?t=73165
[Edit: fixed a mixup of the parts] That's a funny one, by the way. As you can see in the photo it has two different types of grommets; in total five of the shorter ones, and two longer; three on the idler plate, and the remaining four on the motor mounting plate, making for a double insulation of the motor from the chassis; of course it has two idler wheels too.
What I'm currently after is the longer type, since that is what seems to have been used in less ambtiously designed decks with only three grommets. But of course I'll also make the shorter one too, should somebody need one.
[Edit: fixed a mixup of the part numbers] From what I've found the longer grommet has the JVC p/n M4728, called "Rubber bushing". The shorter one is 52992-1.
So, what I'd love to hear from you veterans are things like this:
Any other JVC models that may have used these parts? Perhaps even with part numbers from service manuals?
Has anybody met these parts in some other turntable brand? From a more modern, post 60s perspective they are a funny design; a hollow cylinder with a straight 6 mm ID, and small dimples at both ends for reducing the contact / vibration transmission area. This design would seem a bit lacking, since the cylindrical form doesn't offer an as good use of the rubber's lateral damping as the more common conical shape would have done. But on the other hand this may have improved the lateral stability of the motor. Also the unusually high thinner end with its dimples is a bit odd: normally that part of motor mounts shouldn't be in contact with any surrounding parts, hence not needing the height nor the dimples. (The motor mounting plate sits in the slot of the grommet, and then it all rests on the tip of the longer end; what would be in touch with the top end?). Has somebody here possibly seen in some other tt model what this part of the design may have been inteded for?
And of course any additional info or problems that I may have missed this early in the job.
