Does your Fisher specify "5V4GA"? If you can run the earlier 5V4G type, these are the way to go (photo attached)...
I'm using a Russian 5v4 right now but I want to get one of these RCA's. :yes:Does your Fisher specify "5V4GA"? If you can run the earlier 5V4G type, these are the way to go (photo attached)...
Are the GA's a later version? Supposed to be less finiky?
Correct, GA's are the "improved" version. Since your Fisher does call for the 5V4GA, the Sylvania 5V4GA black plates are the way to go, and are relatively cheap (about $20 NOS/NIB).
Man, do not hot switch these tubes, they will arc over nearly every time.
BTW, I noticed that on the 5V4GA that I have, there are fewer tube pins than holes in the socket. I take it this normal.
I need to replace the 5V4GA tube in my Fisher TA-500.
I'm thinking I should get a good vintage U.S. made tube.
Any preferences? I've heard they can have a bearing on the sound.
Thanks!!
NOS RCA 5V4GA= $50
I wish that were true: I could retire! Years ago when 5AR4s were getting expensive I bought a big stock of 5V4GA tubes to use in applications where the 5AR4 was not necessary. Unfortunatly, I don't see any 5V4GA tubes on epay for $50 except for someone in Italy. The cheapest is $10 with no bids.
As long as it tests strongly and has no noise issues, no problems.Old thread, yes, but I just picked this 5V4G off the popular auction site for $5.99 this past weekend; en route to me now. Is there any reason why I cannot use this boy in my Fisher TA-500 receiver that technically calls for a 5V4GA rectifier?
Thank you.
