The pics I've shown are two slightly more recent varieties of AR's 1-1/4" tweeter that should work as a replacement in your AR-7.
First, are you positive that your original tweeters are dead? What happened? Have you hooked them up to a meter or tested them out of the speaker cabinet? Is it possible that the exposed exterior tinsel wire has become disconnected somewhere?
If they are in fact dead, then next thing is to measure diameter of magnet or more importantly, diameter of cabinet cut-out. If they can accept the tweeters with 2-3/8" dia, magnet, then any of the more recent drivers will work, although it will take a minor wiring modification. In this case, you'd need to disconnect the green and yellow wires inside the cabinet that connect to these front-mounted terminals, and simply connect those wires directly to the rear terminals of the replacement tweeter, now inside the cabinet - - and preferably to use a female crimp-on spade connector like shown here.
As far as obtaining replacements, if you become a subscriber you can have access to the Barter section of the AK site, which is a great resource. And then there are online auction sites - - for instance, I found this tweeter shown (second pic) currently for sale online. BTW, do you need a single or a pair?
Third pic shows original tweeter backside of my AR-7's - - these magnets are the smaller 2-1/8" diameter, but without digging into my speakers I cannot confirm the diameter size of the cabinet cut-out. You should first confirm exactly what you've got before making any decisions so that you are at least partially prepared to make any modifications which might be necessary to accommodate a replacement tweeter.
