Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Picked this lonely AR speaker up at an auction for nearly nothing this evening. I want to make it a pair, but need to know what I am looking for. It looks like an AR3 to me, but I dont know whether it is an AR3 or an AR3a.
You have the earlier 3a with the more desirable Alnico cloth surround woofer. Don't be surprised if you get little or no output from the mid or tweeter. The pots are notorious for corroding, blocking the signal to the drivers. If this is the case, turn them back and forth a lot, and you may find a sweet spot. Regardless, it's good to pull them for cleaning and inspection. Plenty of threads covering the process.
So now you need to find a mate, these are fabulous speakers once recapped and restored.
Glenn
Thanks everyone. So if I buy a non early 3a, is it just a woofer swap to match my current one, or is it more involved? I assume I may have trouble finding a single of the right vintage since mine was made during the transition?
Crossovers are different but can be done. You do have a 3a badge on the grill. The AR3 grill cloth is different and the tweeter is different. There is not a lot of early 3a's so you may get lucky or wait a long time to find one. I am guessing with fixing your current one and finding one that will also need work will run you close to $500 or more. Good luck.
