AU-20000 vs. BA-3000
Orcinus
I received my AU-20000 service manual today (finally! Took nearly a full month to get here!) and I noticed that the bias current is specified at 35 mA. Now, as we all know, the AU-20000 is a melding of the CA-3000 preamp with the BA-3000 power amp, of which I have the service manual for (downloaded it from the 'net). However, the bias current for the BA-3000 is specified as 20 mA. Does anyone know why this is? Will an incorrect bias current in my AU-20000 (i.e. set to 20 mA instead of 35 mA) cause any problems at all?
I'm really curious as to why these supposedly identical power amplifier sections have different bias currents... :scratch2:
Tight space
Thats a good question, the other one is how do you fit a CA-3000 and a BA-3000 into a AU-20000. I know the spec,s 170 wpc for the amp section are the same, but I am still confused. :headscrat Perhaps there are some reasons why the bias ratings are not the same. Lastly Orcinus, where can I find that BA-3000 service manual?
What makes you so sure that the amp section of the AU-2000 is the same as the BA-3000?
- Pete
the service manual can be downloaded here http://www.classicsansui.net/Schematics.htm
cant help you with why the different biasing but could it be because the ba 3000 can be bridged to mono?
- Pete
Because Sansui themselves have said so, it's well documented. Also, the schematics of the power amp section of the AU-20000 are pretty much identical to the BA-3000, except for the bridging circuitry (which just inverts the input of one channel, and you use the two positive connections for your speaker output)
Hmm, there's a thought... but any amplifier with a common-ground output on the speakers can be bridged simply by inverting the input of one channel and then using both positive connections (skipping ground) for the speaker. (the AU-20000 does indeed have a common speaker ground)
I did a little homework since making that statement. The amp sections do indeed have a lot in common, right down to the component layout.
- Pete
Nudes
AU-20000
BA-3000
