I am wrapping up a rebuild of my AU-717 and was been thinking of installing a new mains cable with a ground wire, and properly grounding the chassis.
I know from testing continuity that the RCA sockets (shield) are connected to the chassis, so obviously this means the audio ground isn't 'floating'. If I ground the chassis via a new mains cable, I may introduce hum.
I built a Pass F5 amplifier recently that floated the audio ground from the chassis using a CL-60 thermistor and monolithic diode bridge in parallel. The audio ground is essentially isolated from the chassis unless there is a fault causing the audio ground to be energized.
So I was thinking... I know there is a spot between the two driver assemblies where two black wires connect to the chassis. One is from the equalizer board (can't remember where the other connects). What if I tied these two black wires together, then put a monolithic diode bridge / CL-60 between them and the chassis. Assuming (big assumption) this is the only place where audio ground connects to the chassis, then it would now be floating. And if I installed a new mains cable grounded to the chassis, then it should now be safely grounded without hum.
I've read another thread where someone suggested chassis grounding without floating audio ground should be ok, but I have a feeling there's a reason why manufacturers tend to isolate audio ground from the chassis...
Any thoughts? Of course I will experiment by grounding the chassis to a receptacle directly (easy with Schuko sockets) and see if there actually is any hum, before I do anything more complicated.
