Underworld
I have an au-717 that is not working. Initial troubleshooting:
1) all fuses test good
2) no bias voltage on either channel (no change with adjustment either)
3) test on each channel for voltage on 12 to 3 shows erratic voltages... 380ish volts, then 70ish volts, then 0... it doesn’t stabilize. 12 to ground shows same.
4) test on power board for voltage at 21 to 23 and 22 to 24 shows same erratic voltages... 380ish volts, then 70ish volts, then 0.
This all makes me think the power board is bad... not sure what to treat next to narrow down the issue.
any help is much appreciated!
