Audio Technica AT630 Step up transformer
arcorob
Addicted Member
This legacy device is awesome. I contacted AT trying to get a schematic hoping it could be the basis for a build...no luck..they just had some old literature as they said this unit is very vintage..but at least they were able to provide the specs...pretty cool...
Amazingly simple device
Want one.... really.
Dead dead quiet...no hum,no hiss...like adding a cable...but one that steps up 1:15 perfect loading (at least for 10 to 20 ohms carts)
The AT650 is another nice one and that one is adjustable..and more expensive...LOL
Just spotted this on the bay:
Moving coil cartridges require a step-up device for standard magnetic RIAA phonograph preamplifiers.
INCREASED GAIN FOR LOW OUTPUT MOVING COIL CARTRIDGES OR RIBBON MICROPHONES
Tested with low output Moving Coil Cartridges.
Quiet with an Extended Smooth Top End and deep punchy bass..
Moving coil phonograph cartridge step-up transformer
High quality gold plated input and output RCA jacks with input ground connector.
Heavy duty construction cast aluminum power coated case.
Input impedance 300 "Z" Output Impedance is 40K ohms "Z".
Frequency response measures 10Hz to 30,000hz plus or minus 0.2DB. Minus 3 DB at 40,000Hz.. Wow.
Voltage Step-up measures about 15:1, 2 mv gives about 30 mv, better than 10DB.
Variable Resistance Cartridge Loading Control included as you can see.
Better sounding than transistorized step-up preamps.
How does this compare to the Audio Technica? This model has a knob for variable resistive loading (unmarked though)
I am almost willing to bet
That if you open it up, it has those microphone Shure transformers inside (or equivalent)
Not sure on the loading but 20db gain is not a lot and look at the freq. response
10Hz to 30,000hz vs 15hz to 100000hz within .5db
Both are 1:15 step up...
The variable loading is cool but no way of knowing WHAT you are loading unless that dial has click stops for loading and he tells you how many ohms each
Send him an email :yes:
I recently bought a new (Bryston BP17 Cubed) pre-amp which, fortuitously, has a phono input, but only MM. So, to try it with my (vintage Mayware) MC cartridge, I needed a step-up transformer and discovered I still have my AT630 which I've not used in nearly 40 years! I'd forgotten all about it.
In conjunction with the Bryston pre-amp's outstandingly quiet and transparent MM stage, would it be better than my Dynavector P-75 outboard MC phono stage? To my great and pleasant surprise... YES! A real classic.
I recently bought a new (Bryston) pre-amp which, fortuitously, has a phono input, but only MM so, to try it with my (vintage Mayware) MC cartridge, I needed a step-up transformer and discovered I still have my AT630 which I've not used in nearly 40 years! I'd forgotten all about it.
In conjunction with the Bryston pre-amp's MM stage, would it be better than my Dynavector P-75 outboard MC phono stage? To my great and pleasant surprise... YES! A real classic.
Welcome to AK! :music:
Info like your comparison is always valuable, thanks! Which Bryston?
If you do open it, make sure it's on some newspaper. There's a lot of gooey, black sticky stuff in there - the foam deteriorates, well, mine had. lol
There was no written info on the transformer(s).
I re-flowed the solder joints and replaced the cables with some Mogami (2549 IIRC). This made quite an improvemnt to the sound, at least in my system.
The rotten foam/goo was replaced with small bubble-wrap - after taking ages to clean said goo with IPA.
For the price they go for on ebay they are a useful tool, if they have the correct impedance for your cartridge. I was using an AT.
I'm sure it's a 1:1.5 (ratio) audio transformer with a simple stereo volume control, totally passive.
The AT630 doesn't incorporate any sort of volume control or, indeed, any other adjustability. It either works with your cartridge as is or it doesn't.
You would have to be a complete lunatic to put a volume control on a step-up transformer. And a turns ratio of 1:1.5 would be completely useless.
The AT-650 has a rotary switch to select between three different turns ratios and has a "pass" position. Unfortunately, Audio Technica's spec sheet doesn't say what the turns ratios are, only that they're intended for cartridges with 3 ohm, 20 ohm and 40 ohm source impedances.
I recently re-wired one of mine using the same cable. The results are a bit strange. On one system using a NAD 7100, it sounds fine. On another using a Decware ZP3, it sounds horrendous. The whole entire soundstage is about 3’ tall and 3’ wide. When I try the other all stock 630, it’s spot on and sounds great. I’ve been trying to use the rewired 630 on the 7100 as much as possible, perhaps the cables need to break in.
All I can suggest is that you open it up and check the wiring. Sounds like something has gone awry - wire touching the case? Poor solder joint? - No offence meant. I did reflow the solder on the remaining joints.
Mine was straightforward except for cleaning the goo. I'm not sure how cables 'break-in' TBH. Especially at such a low voltage - or any for that matter.
Should have also mentioned, I stuffed the case with cotton wool. All the old spongey gooey stuff was a mess.
No offense taken on the soldering, I’m no pro! Sometime this week I plan to crack it back open.
Good luck with it. For the life of me I can't remember what it looks like inside, except for the transformer and the muck.
I think I've fettled too much kit and it's all blurred into one. rofl.
All better now. Somehow, likely while sliding the cover back on, one of the solder pads lifted and the joint wasn’t very solid. I also left out the packing I had in there.
