ArDrakho
Well-Known Member
Howdy! I was reviewing the specifications for the M-Series. I located the specifications for all four: SL-M1, SL-M2, SL-M3, and SL-MA1. For M1, M2, & M3, the platter is denoted as an aluminium die-cast and measuring 325mm and weighing 2.5 kg. However, I looked everywhere online and I cannot determine if the platter for the Sl-MA1 shares the same weight as the M1, M2, & M3. Although, I know for certain it is also aluminium die-cast and measuring 325mm as well.
Does anyone here can verify that the platter's weight for the SL-MA1 is the same as the M1, M2, M3 (i.e. 2.5kg) or different. If different, what is its weight?
Thank you in advance
