B2 Red Light Replacements
MiamiBoy
I need to replace the two RED lights on my B2 for the power and protection lights. I have searched through all the other B2 refurb threads and did find references for replacing the incandescent lights but could not find anything about these red “LED” lights. Can anyone point me to a replacement part for these lights? Thanks.
Are you absolutely sure they are bad.. How did you test them ?
The foam that attaches the little boards has likely crumbled and the little LED boards have fallen out of place and view through the pin hole.
Yep, that was it. They both got misaligned with the holes. Hate when that happens. :rolleyes: When I took the face plate off and powered the amp on both red lights worked. Thank you.
