Balanced vs Unbalanced Connections
Dave918
Banned
The Marsh pre-amp and amp that I just acquired have the option of using balanced or unbalanced connections. My question is - what's the difference between the two and is there any benefit of using one over the other? I currently have them connected with standard patch cables, which is unbalanced.
Also, the balanced ports are XLR, so would I use a mic cable like this one
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=241-340&scqty=2
or is there a specific cable I should use.
Thanks,
-Dave
Found the following out on the web. So, a balanced connection provides better noise cancellation - correct?
The Problem
A recording studio can have miles of cable running from here to there and back again. When making cable runs of any length it's important to be able to reject any noise that may jump onto the line from a number of sources. Radio Frequency (RF), noise from dimmers or fluorescent lighting, CB radio transmissions, AM/FM radio transmissions and more can end up hitchhiking along with your signal. Think about it, when you lay out a length of cable you are essentially making an antenna. When you lay out thousands of yards of antennas it can be a nightmare.
The Solution
The best way to remedy this is to used balanced connections throughout your studio. The difference between balanced and unbalanced cable is an extra conductor in the wire. An unbalanced connection runs two conductors, a hot (+) and a ground. A balanced connection runs three conductors, a hot (+), a cold (-), and a ground. What makes the difference is not in the cable but in what happens at either end, before and after the signal travels down the cable. Any cable can be an antenna and a noise collector.
First lets look at balanced connectors. You can see that they come in two common forms, one is an XLR or cannon plug and the other is a TRS 1/4" connector. Don't confuse this balanced connection with the balanced connector that's used on some consoles. On a number of Mackie consoles for instance, they use a TRS to run an insert in and out of the board. This is not balanced but using the three connections as in, out and ground. One connector does the job of two and it's not balanced.
What makes a balanced connection work, is some electronic trickery that makes the noise on the line phase cancel itself out of existence. (Remember our feature on Phase?) Here's how it happens. A balanced connection first runs through a differential amplifier which splits the hot signal into two and flips one half 180 degrees out of phase. This travels along the cable as plus and minus along with the ground on three separate conductors (on an XLR, pin 2 is hot, pin 3 is cold and pin 1 is ground). Along the way, the usual noise is encountered and picked up by the line. At the other end of the connection, the minus is flipped back into phase and you end up with a plus and a ground again, just as it was when you started. The difference is, that now the noise is out of phase with itself and cancels completely.
Hi Dave:
Balanced cables that utilize the 3 pin XLR connectors (such as seen with microphones) offer better immunity to noise (hums, buzzes, eletromagnetic interference, etc..) than the the typical 2 pin rca unbalanced connector.
It is more common to see balanced lines in Professional Sound & Recording equipment applications - obviously if someone is recording music to create an album (cd) or is performing a concert in front of a live audience, in which case sound quality-degrading Noise is unacceptable. Low impedance mics use use balanced connectors- that way, the mic cable itself can have a longer length (to reach wherever it is going to be connected to) and not be as susceptible to noise interference as an unbalanced mic would be- that would have to have a much shorter cable length otherwise the noise level would be unsatifactory.
Balanced cables have an extra pin (3 vs 2 on the rca)- thus they are designed to carry two identical signals that are out of phase. Along the signal path the design is such that the desired music signal passes thru and the noise itself is isolated and cancelled out.
It has been more common in recent years for professional balanced lines to be utilized in hi end comsumer audio equipment.
So, to answer your question - if your preamp and amp have balanced connections- then by all means take advantage of them! In order to make the whole path balanced, you can also consider getting a cd player that has balanced outputs- so that you can connect the cd player to preamp via balanced cables as opposed to rca.
Regards,
B/F
Thanks BF, I think thats what I'll do. As you say, they're there, so why not. The the pre does have a set of balanced inputs, so I may have to look into a balanced source also.
-Dave
As long as you've got 'em, you may as well use them. But if you wind up incurring any serious additional costs, it's really overkill. Unless your cables are running 50ft or more, the difference will be negligible at best.
Also if you are using any equipment made in the UK, you may run into problems with the pin configuration. Britain uses the 2-pin as the hot connector and you may need to invert.
Again, if it becomes a hassle I wouldn't worry about it. I've worked in recording studios and live sound for years and in live applications it's essential because of long distance runs and high power currents involved. But in a home setup, its more of a luxury.
