tekuhn
I have a strange situation that I'm hoping someone more experienced can explain to me. I am installing a Celestion TF1225 driver in a ported 2.6 cu.ft. enclosure and having a hard time getting the ports tuned. The drivers advertised Fs is 63Hz and mine measured 60Hz in free air. Using WinISD, I have decided to tune the box to 57Hz for the desired alignment. When I made the ports the dimensions specified by the calculator, the tuning dip showed 41 Hz instead of the expected 57Hz. As I shorten and widen the ports to raise the tuning, I can never raise it to the desired tuning. When I tune the box to make the two impedance spikes equal, it shows the tuning to be about 45 Hz. My understanding is that when the two spikes are equal that the box resonant frequency Fb and the driver resonant frequency Fs are equal. Shouldn't the tuning dip show about 60Hz when the spikes are equal? I have tried removing all the foam to make sure I don't have it over-stuffed, and it doesn't significantly change anything. I am checking impedance using REW and a homemade test box which calibrates perfectly and I trust the results. Any ideas what's going on?
