H_Johnstone
Inherited both the BM1400 and BM1600 old series receivers.
When I fixed them up, new capacitors and output transistors,
the series regulator (negative) providing single 30V rail, gets
really hot at load. (AC-coupled) Classical problem...
If I provide unregulated supply to the output stage only,
dropping the GND by -15V to a total of 45V, How much
of the output stage do I need to resupply (convert)?
Can I use coupling capacitors in between?
All for minimum modification to the circuit.
(Sch. output stage provided)
Many thanks for your input
Sincerely, Howard J.
