So I'm repairing a Beomaster 4000 for a friend. After some work, I got it to bias correctly and went to play some music. The first time I listened, no major issues. I did notice that, after being turned off, it took a second or two for the music to fade out. I assume this is a function of being a cap-coupled design and/or not having a speaker protection relay.
Upon being powered up a second time, there was an initial burst of static through the speakers -- this faded within a second or two. During playback, I could hear audible distortion in the left channel. When I cut the power, the speakers again made a loud static noise. In the right channel, this persisted for at least ten seconds after the power was switched off. It might have been occurring in the left channel as well, but I was sitting next to the right channel speaker so that's what I noticed.
I'm wondering if anyone recognizes this behavior. I did not work on the unit at all in between listens, although I did flip some preamp switches. I'm assuming this is a power amp issue -- maybe failing caps? However, I'm a little perplexed as to why it manifested the second time but not the first. Maybe some component was close to failure and having some power through it caused degradation? Any insights very much appreciated.
