Best Cartridge/Stylus Upgrade for Rega RP1
cestwhat
Hey all, I've just finished upgrading the major components of my stereo system and have a 1989 Yamaha AX500U hooked up to a 2018/2019 Rega RP1. The sound is fantastic but as its been said in the past the original Rega Carbon cartridge lacks a bit of the crispness in the treble and bass power. I have heard variously from folks to consider using the DYNAVECTOR - DRT XV-1S MC Phono Cartridge or using the Rega Carbon cartridge but with an LP Gear CF3600LE stylus to improve the treble and bass responses. What are folks thoughts here?
Do we know the effective mass of the RP1's tonearm (RB101?). I suspect it might be on the light side, in which case it would be better going higher compliance than the Rega Carbon and its spin-off styli that track at 2-3g (suggesting a compliance on the low side). I would suggest the Ortofon Super-OM10 for consideration as a first step, which is good a the low-end and top-end.
Dynavector on an RP1 ? I would not put an Ortofon Quintet on the RP1 tonearm. I replaced with tonearm with a RB 202 and then put the Ortofon Quintet Blue on it. We are talking about a RP1 aren't we ? You won't get much bass out of it no matter what cartridge you put on it with that plastic platter.
