A Luxman SQ38FD Came across the bench.
I cannot seem to find any info on recommended bias setting for the 50CA10. Another tech installed some 10ohm resistors from Cathode to Ground. On initial measurements it looks like someone was aiming for around 30mA but this seemed a little low. I used the bias/balance pots in the output section to dial each tube into about 40mA across the cathode resistor. I could not even find the 50CA10 in the RCA Receiving Tube Manual.
Any advice would be greatly appreciated.
