Bob Crites New CD53P Midrange Diaphragms
SET12
Hello All,
Bob Crites new CD53P Midrange Diaphragms are for Klipsch Heresy II, Cornwall II, Quartet, Forte, Forte II, Chorus, Chorus II, and KLF Series speakers.
While visiting Bob's website I happened on his new midrange diaphragms which I was told are just a couple of weeks into his offering under Other Klipsch Midrange Drivers here
http://www.critesspeakers.com/klipsch_midrange.html
What really caught my interest is when Bob said,
"This is a high quality replacement diaphragm developed for us. It tests very good in comparison to an original Klipsch diaphragm and better in a couple of ways. It, has slightly smoother frequency response, it extends a bit higher and it rolls off smoother without a bounce back at higher frequencies."
Just how good are they?
They get my :thmbsp: and are highly recommended.
In a short initial impression after having about 10 hrs of listening on them.
"They are very, very smooth, articulate, a full sound, transit attack is nice with no hardness at all, especially with piano which is very clean giving a dynamic and balanced presentation."
Some of my notes during listening.
Shirley Horn, "Here's to Life" Cut 1, Very deep and wide
Titanic Soundtrack, Cut 10 Death of the Titanic. Very good resolve, fine focus and good coherency under high dynamic levels, impressive!
Jimi Hendrix, "Electric Lady" Cut 12 Moon Turn The Tides Gently, Gently Away. Rounder and much more believable. Special effects are put into a new light.
Patricia Barber's "Night Club" Cut 7 Detail of the Bass players fingers on the strings nothing short of amazing. Piano is just impressive.
I was very fortunate and very thankful to have my friend Don available for a listening session. Don was a formally trained musician that played Trombone, music runs in his family. His brother is a music teacher at a local high school and has played in some of the best big bands in the country. Myself I know of few people that have both his live and audio gear listening experience.
Some of his listening comments.
Very Articulate.
A very full sound.
Very fast.
Transit attack is very nice.
From Patricia Barber's "Night Club"
Hardness is gone from his previous visit. The piano sounds clean, keys are down to the real meat and potatoes. Incredible detail of the brush's on drums, cymbals are nice. The system is very dynamic and balanced from top to bottom.
Jenifer Warns, "Hunter" Cut 5 Just a wall of sound. Cut 10 simply huge!
Soundtrack "Master Commander" Cut 1 and 2 Impressive dynamics.
So in conclusion
With the 10 hrs or so on them they are just likely going to get better yet!
I want to add that initially it took about 4 hrs of hard playing before they opened up.
What I mean is the sound stage sounded narrower to me initially and the presentation was leaner as well. If you chose to upgrade to these you should realize that you likely have 100's if not 1000's of hours on your original diaphragms so they are well broke in. I surprise how much they opened up after a few hrs on them with spl's in the mid 90's at my chair as I listened. I did a number of investigations such as high level dynamic response, amplifier clipping, special effects reproduction and so on. Then I thought I noticed the same wide presentation on a recording that the previous diaphragms reproduced. So I went back to some earlier reference recordings and found myself saying "I'll be"
So below is a little info on my installation along with some of my system information.
This includes the following Klipsch midrange drivers:
K-53-K, K-52-K, K-52H, K-57-K, K-58-K, K-59-K, K-61-K, and K-62-K.
Notice the metal phase plug.
Well mine did not have the metal plug so I contacted Bob and here's what he told me.
Dan,
Klipsch bought the original driver tooling from Heppner. I think Klipsch made the decision pretty early to go with the integrated phase plug and eliminate the separate metal one. Anyway, if the driver is labeled as the K-XX-K, then it probably always had the integrated phase plug. If it says K-XX-H, probably would be an original Heppner driver and would have the metal phase plug.
Thanks,
Bob Crites
While the new and old diaphragms look similar they are constructed differently with a different material used for the coils former along with larger holes in the the phase plug.
The new diaphragm is pictured on the right.
From the back side the new one is on the right.
Installation was breeze
http://www.critesspeakers.com/k-53_diaphragm_replacement.html
But I was a little apprehensive as my two location pins did not allow a simple slip on.
So be careful!!! Mine literally snapped into place, with no other issues.
My system is a rather simple one in some regards but not in others.
I am using a highly modified Eric Barbour 811-10 DIY amplifier in monoblock form.These are very powerful amplifiers with 240 Joules/monoblock of energy storage. Translated this 1920uf's @500VDC/mono. They are very fast and use a unique approach in power supply design.
http://www.audiokarma.org/forums/showthread.php?t=274002
My CDP which I use direct via its variable outputs is a Sony X77ES it to is highly modified. It is using 150,000ufs, Panasonic and Muse, Burson Op Amps.
http://www.audiokarma.org/forums/showthread.php?t=185971
Next are the Fortes which are highly modified with outboard networks allowing me to try out new passive parts in a matter of minutes.
For more information see my Thread here
http://www.audiokarma.org/forums/showthread.php?t=159340
Coupling to the CD53P Midrange Diaphragms is done with Bobs T3636 Autotransformer and a Duelund Copper VSF (Virtual Stacked Foil) capacitor on the right side with the Blue wire connected to the green terminal post.
Tweeters are Bob's Titanium diaphragms coupled with Mundorf Silver/Oil Caps and a Duelund 39 ohm Graphite Resistor, North Creek 8AWG .16mh Inductors.
Woofers are coupled with North Creek 8AWG 3mh Inductors, Solen and a Mundorf bypass.
Wire is Audio Quest Midnight, Indigo internal and external and Clear to the amplifiers.
So my hats of to Bob Crites for all his efforts and I'd like to say.
Thanks Bob!
SET12
that is good news for Klipsch-O-philes (and soon to be Klipsch heads) bad news for some of our savings :D...but I bet it will be worth it...okay, so I don't HAVE to do it to every pair...today...:D...thanks SET12...
Bill
Bill
That is true Bill,
I think people should know that Bob told me in an e-mail that it has taken 2yrs of processing to get these to meet his criteria of performance.
:music: to my ears.
SET12
I had just purchased a pair of Titanium tweeter diaphragms for my kg2s when he told me in the next couple days he would be introducing these...within a week there was your news and evaluation Set12...outstanding...
Bill
Thanks Bill,
Since I have had the Titanium's for some time now I feel I can give some real reflection on it.
IMO, I found the tweeter diaphragms to be highly influenced by the coupling capacitors and inductors as well as the paralleled 40 ohm resistor.
Many friends warned me that Titanium tweeters are likely to some a bit hard or harsh.
So one of the things I toyed with was going to a Litz Inductor after reading of ALK's work with making some measurements of the "Q" factors of various inductors which the Solen Litz proved to be very high.
http://forums.klipsch.com/forums/t/38976.aspx?PageIndex=1
So I ordered the Litz .16mh 14AWG's and placed them in my networks replacing the North Creek .16 8AWG's I was using.
The resultant sound was just unbearable from my system the highs were not only over the top being harsh they were actually leaner.
I tried sticking with them for awhile but no improvement came.
When I went back to the North Creeks it was an OMG experience for me with the highs being very,very smooth and lots of body, it was just so right sounding to me. Possible reasons, maybe the lower "Q" and the sheer core size of the North Creeks.
I have had two friends here who I highly regard as listeners and both of them comment that the klipsch top end I now have is among the best Klipsch top ends they have ever heard.
I'd also say the Mundorf Silver/Oil's and especially the Duelund 39 ohm resistor have a large part in the beautiful top end that IMO I have now
Some of my other local club members who aren't fond of horns have commented that unless they were told they would never know that they were listening to a Horn.
Funny thing, the Klipsch Palladium P-39F sounds the same way!
SET12
I too heard the Titaniums would be harsh (...and some big voices on the K Forum dislike Titanium diapragms as well...) but they are inexpensive enough to give them a try...my younger brother had done some work at my house and was looking to upgrade from his Bose...I was Klipsch heavy so I gave him some to try...after A/B -ing Quartets and Heresys, he liked the bass of the Quartets better but the mids and tweeter of the Heresys better...as did his wife...I had never done a side by side test and when I did...I too found my Quartets tweeter just a bit raspy/rougher (if I use any audiophile words it is merely a coincidence) and so made the switch...
What a change after just a bit of listening time...so I tried a pair on some KG 5.5s I had picked up for a 2 channel HT...loved 'em so I tried 'em on a pair of Chorus IIs...sweet...just a few weeks back I reacquired my original kg2s...changed 'em out and again...a dramatic difference...that's when Bob told me of the mids ('course I have none in the 2 way kgs but the Quartets and Chorus IIs...)...so I am really enjoying your write ups and analysis...
Bill
Bill
AHHHH so there are people that don't like them! Well it would be cool to put int the original inductors and give a listen. and even the original caps. Now that would be a write up.
But you know I think the same thing could happen with these beautiful mid diaphragms!
I had a listening session this morning with a buddy that has heard my system from its very early days and he said he was really impressed by how smooth and dynamic it sounded. He's a retired coast guard guy and I played the Titanic sound track Death of the Titanic cut 10 and he was shaken up by it! He literally got the willies from it and said its as though he were there underneath the Titanic as it went down. It was impressive, the new mids are blooming out by the hr on them and right now the mid and top end IOM would very well rival the $20,000 Klipsch Palladium P39F's as remember them. As far as the low end of my Fortes I'd have to say sorry! its no contest especially since I got my grid and anode chokes in my amps its as though I have a new level of pitch definition I never knew I had and those low frequency North Creek 8AWG air core inductors are really showing their stuff with an iron grip like I have never heard! Who says you have to have a Damping Factor out of this world? I'll tell you! the inductor has more to do with tight bass then what most people think IMO.
Pretty exciting stuff.
SET12
Stock Forte vs Modified Listening Comparison.
Well,
I had another listening session this yesterday afternoon with my buddy Farrell that owns the stock pair of Fortes.
I'll try and go into more detail later.
Basically we we used 10 cuts from five of my reference CD's.
We listened to the stock pair of Fortes first.
Then hooked my modified back up in the same position with my outboard networks, there were 16 terminal posts to connect, a real bear but the effort was certainly worth hearing with what we heard switching the stock speakers out.
The volume control was never touched and left in the same position.
The differences were far from anything subtle.
Here are some of Farrell's comments.
"There is frighteningly more definition, So much so, that its sensory overloading."
Making a comment here, I asked him after the first cut on the modified Fortes what he thought and he was clearly just speechless. He said it was just overwhelming to describe and wanted to go into our second cut.
Even myself, I was pretty wide eyed with mouth wide opened. It really took me by surprise. I guess listening the way we did got us pretty acclimated to the stock sound which isn't bad but nothing like the Modified. Which he commented that.
"you wouldn't even know it was the same speaker"
And I agreed.
His third comment.
" I can very distinctly tell where each instrument is and what instrument it is"
This was in some very busy recordings which he told me that the stock speakers have a tendency to homogenize everything tonally making it more difficult to tell what was what for instruments.
Farrell, is a Drummer for his local church and his wife is a Keyboard player organ and piano (they have 100yr old Steinway Piano in their living room), Farrell runs the church's sound system and here he makes a comment.
"I can clearly hear the characteristics of the mikes used for this singer from other cuts of this CD"
His last comment was
"Once you get use to hearing everything separately in the mix, everything sounds much more musically involving"
I think what he is saying hear is that the sense of space was huge in every respect height, depth and width. Layering was phenomenal with a sense of air around everything. But the big point was how all the instruments harmonics where all separately defined within the instruments place on the stage. Things that were over miked were heard as over miked but never harsh.
You know when I was in Chicago for the AK fest this past weekend I had the opportunity to hear a pair of $5000 Alon's at a fellow AKer's home.
What I can tell you is the Alon has a lot of refinement no doubt.
But interestingly these modified Fortes have the same kind of refinement with a sound stage that seems nearly twice the size.
I can't help but compare these to a $10,000 product they are that involving.
The Forte is a real Seabiscuit among Klipsch's IMO. In reference to the famous little horse in the 1930's that thought it was the biggest fastest horse on the track.
SET12
Have some stock Forte IIs... planning on diaphram and Xover upgrades
Swapped out stock mid diaphrams with the Crites, still on stock Xovers
Considering the cost and ease of diaphram swap, along with the sonic changes, this is literally a no-brainer!
Can't wait to see what the Xover upgrades have to offer along with the mids
Thanks for the info and writeup!
Hey,
The x-overs made the biggest difference in my 1983 Cornwalls.
I did the tweeters, mid range diaphragms /red rubberwashers, and the x-overs. Back in 2013. If memory serves me correctly. Eric
