Brisket Time!
StevenZ
Texas or nothin'
Finally had some down time and convinced my parents to take my kid or the day/night so the pregnant wife and I could relax a bit. Decided along with the yard work I had to take care of I decided to throw a brisket onto my pellet grill (Grilla Grills brand, Silverbac model).
I picked up a brisket at my local HEB grocery store a couple days ago and noticed that they didn't have much in the way of selection, however the HEB I visited isn't known or catering to people of higher tastes and budgets so pickings were slim. While there were quite a few briskets to choose from, they had zero prime grade (and no section for them) and had only "Select" grade but these briskets were trimmed already and the prices here for "trimmed" briskets are ridiculous. So I wandered a bit further down the aisle and came across some full packers. The prices were REALLY cheap compared to what I'm used to, and aside for a USDA seal on the package, there was no grading. I assume these are below "select" and closer to commercial grade or something like that. That explains how I walked with a 14lb packer for $24.
So, not quite off to the right step, but optimistic being as I've seen others turn out good product on low quality meats, I set off to not only achieve the right tenderness, but also get the right bark that I prefer for my briskets.
I decided to trim my brisket last night and apply a base coat of worcestershire sauce to help the rub stick. My first layer of rub was a reliable SPG mixture (Salt, Pepper, Garlic) 3:2:1 ratio. My next coating was a 4:3:2:1 mixture of Paprika, Salt, Pepper, Coffee grounds (espresso grind). I applied a heavier second rub than first and wrapped tightly in cling wrap to let sit overnight.
By 5:45 this morning I had the smoker up to temp, 235F, using Rec Tec Comp Blend pellets (not my normal choice, but they'll work). The brisket seemed to not weep as much as I expected it to. Not sure if that's a good thing, but when I've done ribs the night before they always wept a bit more. First sign of a poor quality brisket? We'll see.
Attached is how it looked first thing this morning.
4hrs in. Time to start spritzing with 1:1 water/apple juice mixture.
8hrs in, probing tender in about 75% of the brisket, but TOUGH in some spots. This is the strangest brisket I've ever done and for fear of overcooking I decided to wrap it at this point and remove from the smoker and HOPE that by doing so maybe the other 25% of the brisket tenderizes a little. I'm not expecting a miracle at this point, given it wasn't even a graded piece of meat, but the tenderness so far in the majority of the meat is good and the bark is excellent. Lets hope wrapping to rest didn't just kill all the bark.
Average temps in the point were 205, flat was about 203 and 207 in some spots.
Well, I think it will turn out OK with a bit of time. After all, BBQ was largely the result of less that the best cuts.
Lookin good StevenZ. Ya'll are big on beef briskets in Texas. What about ribs or pulled pork?
You might not know that South Carolina is the birthplace of BBQ. The Spanish landed at Georgetown, SC with their pigs in 1520 and the Native Americans showed them how to slow cook over hickory pits and the rest as they say is history.
OK, rested an hour and a half (I'm hungry!) and as I figured it would be, the flat is a bit dry, but it has excellent flavor. The point. Man, the point is absolutely perfect. Tenderness is perfect, flavor is explosive (you guys should try this coffee rub!) and perfectly rendered fat. I couldn't hope for better with the point. The flat will turn into stew, chili or chopped beef and revived with some beef broth.
Here's some pics. Strangely the smoke ring on this brisket is nowhere to be found. I noticed this on a previous cook using these Rec Tec pellets as well, so I'll be happy to see them gone from my hopper and replaced with my normal Lumberjack blends. Briskets I've done before always had a near 1/4" ring.
Also, Poultry I can do some awesome ribs (beef and pork) as well as pulled pork. Wife just isn't a fan of pulled pork to do it more often than once a year or so.
And for the record, no more bargain bin brisket for this guy. Once is enough and I'll stick to prime for here on out.
