info on U-Turn Orbit grounding
Below is helpful info I received from U-Turn in response to a question I asked about grounding options for the Orbit TT. I am posting here in case others are interested. FWIW, I really appreciated the manufacturer responding to my questions and providing this technical info! e_identity
Hello,
Thanks for getting in touch. The turntable is grounded internally through one of the audio channels, similar to some high end models like Rega's, among others. Let me know if you have any other questions or concerns.
-------- Original Message --------
[name],
Thank you very much for this prompt and informative response.
I have one additional question.
I understand that the turntable is grounded internally through one of the audio channels.
Is there any provision for connecting an external ground wire to chassis ground on the TT?
Using custom connectors, I will be going out from the RCAs to a balanced in. On the TT end of the custom connector, I would like to connect the shield of the connector to a TT chassis ground. I saw a picture of the board on which the Orbit RCA outs are mounted, and it appeared to show what might (or might not) be a ground screw that I could use for this purpose.
Thanks,
[name]
Hello [name],
There is a jumper on the tonearm PCB that allows you to disconnect the channel ground completely. You can then attach a separate ground wire directly off the pin on the PCB. Keep in mind there is no external ground screw so you'll have to remove the metal cover to install your cable.
Hope this helps and let me know if you need any other information!
[name]
