Recently hooked up my turntable to my C28, which has been sitting idle for a few months. I plugged into phono 1 input and noticed the left channel was quite a bit weaker than the right. Switched to mono and things evened out. Figured it had to be the preamp.
Plugged the turntable into phono 2 and the signal seemed even weaker. Then I looked over and noticed that it was still set to phono 1 but a weak signal was coming through. Turned the input selector to phono 2 and both channels were coming through loud and clear. Switched to the other inputs and there was phono signal coming through all except Aux and Tape.
So the question I have is what can be causing this? I know, the answer is a lot of things can be causing this and you won't know unless you open it up and test it, but was wondering if anyone had a hunch on what it could be.
After some quick research it could be the selector pot being dirty since its been sitting for a while, but didn't aggressively turn it to see if that fixed it.
Thanks for the help!
