Chris Lauver
Hello, I have an old Magnavox Imperial series console from 1972 that I would like to re-cap the head unit and amp. The problem is, some of the capacitors are not common values. I know you can up the voltage, but can I change capacitance as long as I stay within the tolerance? The ones I am wanting to replace are all Nichicon and marked as follows. 20MFD-20v, 20MFD-15v, 200MFD-20v, 250MFD-10v, 300MFD-35v, and 500MFD-50v. Also, there is one axial marked 20MFD-15v. Thanks for your help.
